1. AndroidFan128's Avatar
    I have a Mi A1 and I'm cutrently using Brave Browser. Sometimes when im just surfing thr web it gets to 36 C°. My idle temp is usually 33.2 C°. Pls help.
    05-25-2018 12:18 AM
  2. Rukbat's Avatar
    Using an app may warm the phone up, but 36° isn't overheating. The maximum you should let the CPU go to (for short bursts) is about 60°C, but 36° is a long way from that. Even the normal "hard use" temperature, 40°-45°, is a long way from 36°.
    05-25-2018 12:26 PM
  1. Why is my map blocked?
    Last Post: 05-25-2018, 04:58 PM
  2. Replies: 1
    Last Post: 05-25-2018, 01:58 PM
  3. How to use mirror link to cast phone to screen in car
    Last Post: 05-25-2018, 01:38 PM
  4. Replies: 1
    Last Post: 05-25-2018, 05:13 AM
  5. Is Essential finished?
    By Scienceguy Labs in forum Essential Phone
    Last Post: 05-25-2018, 02:49 AM
