1. Imransahil's Avatar
    My phone (micromax q413) is showing UNFORTUNATELY, DMG HAS STOPPED i am not able to close it, and
    05-29-2018 04:47 PM
  2. Rukbat's Avatar
    DMG appears to be a music player that doesn't work. Find it in Settings/Apps, tap DMG and uninstall it.
    05-29-2018 09:17 PM
  3. GreatEmperorAca's Avatar
    i have the same problem and i dont even have that player
    05-30-2018 02:00 PM
  1. Can I record phone call on my galaxy jj3 luna pro
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 08-15-2018, 05:26 PM
  2. Does anyone know of an app or method to remove all reminders?
    By coffee-turtle in forum Android 7.0 Nougat
    Last Post: 06-04-2018, 05:02 PM
  3. SD card simply loses files.....I know..it sounds crazy
    By Scott C3 in forum Ask a Question
    Last Post: 05-29-2018, 10:48 PM
  4. Want to remove Emoji reactions at end of comments
    Last Post: 05-29-2018, 05:55 PM
  5. Replies: 1
    Last Post: 05-29-2018, 05:52 PM
