- May 9, 2018
- 17
- 0
- 0
I have an old LG G3 phone with Android 6.0 ("Marshmallow") and it was easy to use almost from day one.
My father bought a Samsung S6 with Android 7.0 (Nougat) and it is just horrible. I thought a newer version on Android would be easier to use, but it's not.
I can't arrange icons simply by dragging them, or Remove apps by simply dragging them to "Remove" box at the top, like I can on my LG.
Dad is older and doesn't know to close open apps once he is done with them, so he can have a dozen active processes running at once. When I tried to close them one at a time, the app window would move on me. The "Close All" prompt would disappear before I could move my finger, and when I did catch it, it never worked. It took me about 12 minutes to finally close every running app.
I sent a photo using messaging and never told me if the send was successful afterwards, so I ended up sending the image twice.
v7.0 on Dad's Samsung shouldn't be such a PIA when v6.0 on my LG works so well.
Is what I'm experiencing true of ALL phones running the same version of Android, or do different phones work differently? TIA
