1. Tigrowski's Avatar
    I've had an Xperia E5 for around 1 and a half years now. I had no problems with the phone whatsoever, it held charge for around 3 days under my usage but suddenly, four days ago it just became really, really hot on the back and lost charge by around 50% within two hours and then turned off. After charging it back, it lost the charge from 100% to 60% within the first hours of the next day and - again - turned off, without the possibility to turn it back on even though 60% was the last reading. I didn't change anything, install any new apps, I've always been a very casual user of that phone (Wunderlist, GMail, Chrome from time to time). No updates were performed in the past days, no new charger used.
    What may be the problem? I've tried running AccuBattery on it and for example here is the reading from yesterday (lost 76% in a day of barely using it - not as extreme as the examples I mentioned above but I wasn't able to catch those on AccuBattery as it hadn't been installed on my phone back then). The readings seem fine so I'm not sure if the battery itself isn't a problem.
    What do you think?
    06-02-2018 12:54 PM
  2. Tigrowski's Avatar
    No ideas what the problem may be?
    06-03-2018 06:10 AM
  3. B. Diddy's Avatar
    That behavior is common for a failing battery. Does this also happen in Safe Mode? https://support.sonymobile.com/globa...399b11c00699b/
    06-03-2018 11:13 PM
  1. My Lg X Charge makes a constant ringtone noise
    By Steeler77 in forum General Help and How To
    Last Post: 06-03-2018, 11:32 PM
  2. Google and the military
    By Wbutchart1 in forum General News & Discussion
    Last Post: 06-02-2018, 10:23 AM
  3. Replies: 1
    Last Post: 06-02-2018, 09:41 AM
  4. Replies: 1
    Last Post: 06-02-2018, 08:25 AM
  5. delete myhome screen clock and weather.
    Last Post: 06-02-2018, 05:54 AM
