1. Anthony Johnson20's Avatar
    Would like to stop my Bluetooth an WiFi from being turned on by spy app
    06-11-2018 05:28 PM
  2. B. Diddy's Avatar
    Which phone? Why do you think you have a spyware app? Are your wi-fi and Buetooth toggle switches turning on by themselves, even after you turn them off yourself? Or are you seeing wi-fi and Bluetooth using battery in the Settings>Battery ​menu, even though you didn't turn them on?
    06-11-2018 06:51 PM
  3. Anthony Johnson20's Avatar
    Im seeing both of them
    They turn on by themselves an they using data on j7samsung
    06-11-2018 09:43 PM
  4. B. Diddy's Avatar
    Go to Settings>Location>Scanning (or it might be called Improve Location Accuracy​). Make sure Wi-fi and Bluetooth Scanning are off.
    06-11-2018 11:03 PM
  5. Anthony Johnson20's Avatar
    On my j3 an j7 both phones have call forwarding number on them I cant change or delete
    06-15-2018 10:12 PM
  6. B. Diddy's Avatar
    Since that question is unrelated to your original question, I suggest creating a new thread for it.
    06-17-2018 12:00 AM
  7. Tiredofbeingstalked's Avatar
    I made my ex mad last week over text she was shooting me
    I end up with factory reset phone in my hand at 3am
    07-13-2018 07:36 AM
  1. Everytime my phone restarts Instagram uninstalls itself.
    Last Post: 06-19-2018, 06:51 PM
  2. Where do I find the WPS pin for my LG V30 cell phone?
    Last Post: 06-11-2018, 11:02 PM
  3. New (to us) Samsung S7, running 6.0, won't update.
    Last Post: 06-11-2018, 07:02 PM
  4. Replies: 1
    Last Post: 06-11-2018, 06:44 PM
  5. Was my tex actually sent?
    Last Post: 06-11-2018, 04:26 PM
