1. wp patrick's Avatar
    When i start my Nokia 8 i hear a welcome sound by android Nokia what i don't like.
    Can i remove the start sound by settings?
    06-12-2018 04:47 PM
  2. Rukbat's Avatar
    Not by settings, you have to root the phone and remove (or rename is a better choice, in case you want to bring it back again, or need the name because you want to use a different sound file) a file in the system area. (In other words, I'm suggesting that you don't.)
    06-12-2018 05:09 PM
  3. wp patrick's Avatar
    Thank you for your concern my problem now i hear the sound to loud and i want make it softer is possible to install the volume by starting phone.
    06-14-2018 08:08 AM
  1. Replies: 1
    Last Post: 06-13-2018, 01:23 PM
  2. Hisense F20 am unable to receive sms.. Wht can i do to fix this problem
    Last Post: 06-12-2018, 05:58 PM
  3. How can I send my to repear
    Last Post: 06-12-2018, 05:53 PM
  4. why can't i get the BBC news app to work on my Amazon fire tablet
    Last Post: 06-12-2018, 05:13 PM
  5. Replies: 1
    Last Post: 06-12-2018, 02:21 PM
