1. vortexclub's Avatar
    [ Okay, I don't know if this is the right place to post this, so my apologies if I messed up. ]
    My images don't show up in my recent files. I was using an app, and trying to put a picture in, but nothing was showing in my recent files when I went to select something.
    The first two pictures show what my recent files look like from inside the app. The third one shows what my recent files look like from the pre-installed app My Files.
    I've tried force stopping my gallery and the my files app, I've cleared defaults, I've deleted data and cache, and now I'm at a loss.
    Recently I factory resetted my phone because I had forgotten my password, before I restarted this worked with no problem.
    Attached Thumbnails Recent Files Not Showing-screenshot_20180627-061344.png   Recent Files Not Showing-screenshot_20180627-061346.png   Recent Files Not Showing-screenshot_20180627-061552.png
    06-27-2018 06:21 AM
  2. methodman89's Avatar
    After your reset, did go through the settings, confirm the path for the camera?
    06-27-2018 06:39 AM
  3. Rukbat's Avatar
    "Recent files" in an app means recent files that you opened in that app. So in My Files, you see files you looked at in My Files. In the other app you see the files you opened in that app, which evidently are none.
    06-27-2018 03:20 PM
  1. Google play not filling to whole screen
    By Darth studious 71 in forum Android Apps
    Last Post: 06-30-2018, 05:18 AM
  2. Xperia Z1 keyboard not writing in text fields
    Last Post: 06-28-2018, 12:37 PM
  3. Replies: 2
    Last Post: 06-27-2018, 12:34 PM
  4. Why my call system not performing correctly
    Last Post: 06-27-2018, 11:55 AM
  5. Why is my itel A31 phone not displaying incoming calls on the screen
    Last Post: 06-27-2018, 12:55 AM
