There could be something wrong with the sound somewhere on the motherboard, or a connector could have come loose (or a wire might have broken). It's inside the phone, whatever it is, and unless you've already repaired a few phones internally under supervision, I strongly recommend that you
don'ttry to fix it yourself. It should still be under warranty, so let Huawei worry about it. (Back up
everything before giving or shipping it to them - if they're good, the first thing they'll do is a factory reset. See
Backing up an Android Device.)
