Problem with SD card and internal storage-pls help
After installing a custom Android 2.1 ROM, my Archos Arnova 10 tablet cannot recognize SD card nor its internal storage. When plugging into computer via USB cable, I can still access my SD card -- but I can't see the internal storage from computer. Have tried re-formatting SD card many times but it didn't work. Is there any way I can put my internal/external storage to work again? May I flash a new ROM without using the SD card? Or I guess a mount command may help to mount the SD card? Please help.
Really appreciate any recommendation since I'm desperate. Thank you!
P.S. Already root my device with su and terminal emulator.
