1. be Dj96's Avatar
    Can someone please help me... my phone is going out of control only when the data connection is turned on. It's totally fine when I'm using Wi-Fi.also this is all after I replaced my phone's sceen
    One more thing.when I activate data connection with 2G it happens.it touches multiply in bottom of the phone.but with 3G it works fine.and with WiFi also.I am asking if it could be some sort of virus or malfunction thing
    And thank you
    07-08-2018 12:57 AM
  2. belodion's Avatar
    Welcome.
    Presumably you inadvertently damaged or short-circuited something when you were working inside the phone.
    be Dj96 likes this.
    07-08-2018 01:37 AM
  3. be Dj96's Avatar
    If there is a damage why it only occurs when I activate 2G data connection
    07-08-2018 11:16 AM
  4. Mooncatt's Avatar
    Modern touch screens work based on the electrical impulses in our skin. As such, they can be negatively affected from any sort of stray electrical charges. For example, I once had it happen to me due to a faulty USB cable. I'm guessing you accidentally knocked something loose related to the mobile data radios/antenna, or some electrical shielding isn't in place.
    be Dj96 likes this.
    07-08-2018 11:50 AM
  5. belodion's Avatar
    I don’t know, but, as @Mooncatt speculates, I imagine it may be related to the mobile data aerial.
    07-08-2018 02:52 PM
  1. Where have my games disappeared to?
    By Drew Dawg in forum Android 8.0 Oreo
    Last Post: 01-25-2019, 11:09 PM
  2. My Facebook page won't open
    By Android Central Question in forum Facebook
    Last Post: 07-12-2018, 11:59 AM
  3. Why is there a brief blurring effect when I unlock my screen?
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 07-09-2018, 06:52 AM
  4. I clicked on a picture from my gallery, then I touched
    Last Post: 07-08-2018, 04:28 PM
  5. How do i remove the scam amazon spinning wheel malware from my s8+
    Last Post: 07-08-2018, 01:50 AM
