1. Julien_b's Avatar
    Hello!
    My Lg G4 front Camera vibrates continuously and makes a strange noise. Also, on the screen may appear RGB colors. It happens on all camera-based apps such as Snapchat, and it makes them unusable. I suppose is the OIS that is damaged, but I am not sure.
    If any of you had the same problem, please let me know what I can do.
    Link to the video of my camera failing:
    https://youtu.be/0hEawbmog60
    07-11-2018 04:57 AM
  2. Rukbat's Avatar
    It looks like the autofocus is damaged, but whichever one it is, the camera module has to be replaced.
    07-11-2018 01:48 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Is that the front-facing (i.e., selfie) camera, or the rear-facing camera? The autofocus mechanism for the rear-facing camera might be damaged.
    07-11-2018 01:50 PM
  4. Julien_b's Avatar
    It is the rear-facing camera. So I need to replace my camera. Thank you very much!
    B. Diddy likes this.
    07-18-2018 05:40 AM
  1. Replies: 4
    Last Post: 07-13-2018, 01:43 AM
  2. why my phone storage is not showing in file maneger
    Last Post: 07-11-2018, 01:58 PM
  3. Replies: 2
    Last Post: 07-11-2018, 01:43 PM
  4. Some areas of black represented greyish in my galaxy note 8
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 07-11-2018, 04:14 AM
  5. Some areas of black represented greyish in my galaxy note 8
