1. Gabipeta's Avatar
    Back story:
    My last phone was LG G4. I don't have any complains about it, just that it doesn't work anymore. (The repair shop say that main memory chip have broken down.)
    What I liked the most about it:
    Camera - I mainly got this phone for the camera. I wanted something quit good to take pictures. I am not professional, just for my hobby. I really liked manual mode to play with and the quality was good for me.
    Dual SIM card - since I am traveling a lot it was handy to use my main card and to just get a cheap local one.
    SD card slot - since I like taking a lot pictures to have more space for them. And that is what saved them all when the phone broke.
    07-11-2018 10:47 AM
  2. pkcable's Avatar
    Ok based on the way you worded the price I'm assuming you are in Europe. Maybe the Amazon in your country has deals on value priced phones? I know Amazon US does, and some of them are decent! These are the US deals....
    https://www.amazon.com/Prime-Exclusi...cUvbUpU6282291
    Here's a good choice at Amazon.uk.......
    https://www.amazon.co.uk/Honor-10-SI...cUvbUpU6282291
    07-11-2018 02:50 PM
  3. Jenny Hathfield's Avatar
    If you are looking for a good Android device which cost under 400€, you can try Samsung J series. This series are extremely good for me.
    pkcable likes this.
    07-11-2018 10:37 PM
  4. chanchan05's Avatar
    Samsung A series. Better than the J series in terms of performance and features. A bit more expensive though depending on which one you get. The Galaxy A8 is the top of the line A series and has very good cameras. The A8 processors are about twice as powerful as the ones used on the J series and some lower end A series.
    pkcable likes this.
    07-11-2018 11:34 PM
  5. Kirstein Gourlay's Avatar
    I recommend the Motorola G6 and it has dual sim option. Pretty much stock Android and no bloatware. Great camera for price and a really decent phone.
    motorola moto g6 64GB 5.7-Inch Android 8.0 Oreo UK Sim-Free Smartphone with 4GB RAM and 64GB Storage (Dual Sim) - Deep Indigo (Exclusive to Amazon) https://www.amazon.co.uk/dp/B079SQF4...cUvbUpU6282520
    pkcable likes this.
    07-12-2018 12:28 AM
  1. Why u cant put emojis next to ur contact?
    Last Post: 07-11-2018, 12:49 PM
  2. If software is updated in moto G5 the data in the phone is erased or not
    Last Post: 07-11-2018, 12:22 PM
  3. How do you get rid of the blue line around apps
    Last Post: 07-11-2018, 11:26 AM
  4. What games do you play daily?
    By 1a11ous in forum Android Games
    Last Post: 07-11-2018, 11:05 AM
