1. Jenny Hathfield's Avatar
    Is there any app that can Mirror Android to PC and Control it in Keyboard and Mouse?
    07-11-2018 10:35 PM
  2. chanchan05's Avatar
    Samsung has SideSync for supported devices. Not sure if Flow has been updated for it already.
    There's also Mobizen.
    I've used both with no issues.
    07-11-2018 11:32 PM
  3. B. Diddy's Avatar
    AirDroid also allows you to mirror the phone's screen to the computer screen.
    07-12-2018 12:35 PM
  1. Replies: 2
    Last Post: 07-12-2018, 03:32 PM
  2. How to uninstall caller ID and block
    Last Post: 07-12-2018, 05:50 AM
  3. Is it the LCD or Digitizer?
    By MrsHubert in forum General Help and How To
    Last Post: 07-12-2018, 04:10 AM
  4. How can I get Sarah.runtnc.net off Android?
    By AndroidPerplexed in forum Android 4.4 KitKat
    Last Post: 07-12-2018, 01:51 AM
  5. How do I change the background for my Message/Contact apps?
    Last Post: 07-11-2018, 09:54 PM
