1. mattdeezly's Avatar
    So I brushed off the dust off my K1 (stopped using it after I got my s8+) which I hardly used anyway. I fully charged it, and start using it. But I noticed the battery is wacky. I watch one 20 minute anime or any video and it drops 10%. Is this normal? I have the screen brightness pretty low to. After that I did a fresh factory wipe and its still doing it. Do you think I have a bad battery or is this normal performance for the tablet?
    07-12-2018 02:12 PM
  2. Mooncatt's Avatar
    It's very possible this is normal. It's an old device, which can cause list battery capacity from age alone. The level of charge and how long you had it in storage can also impact battery health.
    John in Michigan likes this.
    07-12-2018 02:17 PM
  3. mattdeezly's Avatar
    thanks for your reply!
    what you're saying makes sense, as newer software that was not originally designed for this tablet might be more taxing on it. I never thought of it haha
    is there any good way to tell the health of it though? I doubt an app could really do much unless it had root access
    07-12-2018 04:02 PM
  4. Mooncatt's Avatar
    Actually, updated software isn't likely the main issue. It's the age of the battery and possibly the storage conditions (especially if stored outside the 40-75% range) that I think would play the biggest role in your case.
    You can try the AccuBattery app. It's fairly reliable for getting a general idea of battery health.
    07-12-2018 05:06 PM
  1. Replies: 1
    Last Post: 07-17-2018, 02:40 AM
  2. Why I cannot update my wells Fargo app I try but is not letting me do it
    Last Post: 07-14-2018, 02:01 PM
  3. My gallery is replaced with symbols
    Last Post: 07-14-2018, 01:56 PM
  4. My web browser on my Samsung Galaxy j7 keeps crashing. What do I do to fix this
    Last Post: 07-12-2018, 06:35 PM
  5. There is a long pause in my voice to text
    Last Post: 07-12-2018, 01:57 PM
