1. Always Learning's Avatar
    Yesterday for example I wanted to try the app ES File Explorer and when it loads the apps it only loads the few I have downloaded lately. It won't load the rest of the regular apps or system apps. Any help appreciated!
    07-20-2018 11:58 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you trying to use ES File Explorer to look at the directories that your installed apps use? File manager apps aren't very useful for that, since most apps have directories that are protected by the system, and therefore not accessible by a file manager app (which makes sense, because you don't want to go into one of these directories and accidentally delete important files).
    07-21-2018 05:41 PM
  3. Always Learning's Avatar
    Sorry for the late response, thanks B. Diddy. I wanted to see if it would load my apps (non-system) and as expected it wouldn't.
    07-27-2018 02:59 PM
  4. B. Diddy's Avatar
    I just want to clairfy what you're asking -- when you talk about "loading the app," do you mean being able to look inside the app's file directory using ES File Explorer? (When most people say "load the app," they're usually referring to opening/running it.)
    07-27-2018 05:37 PM
  1. Google app crashing
    By slave in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-14-2018, 03:08 PM
  2. Yahoo mail android app screenshot not working
    By Ank Chau in forum Android Apps
    Last Post: 07-20-2018, 08:48 PM
  3. Replies: 5
    Last Post: 07-20-2018, 05:28 PM
  4. why is my bluetooth headset not charging?
    By r_rainah in forum Ask a Question
    Last Post: 07-20-2018, 11:03 AM
  5. Samsung Music app won't play music through headphone
    Last Post: 07-20-2018, 08:53 AM
