Pdanet+ (waiting) Direct wifi hotspot but no wifi connectivity
M Knight
So I want to be able to use my S8 as a hot spot. My hotspot option in settings is disable by Carrier I guess. So I got PDAnet+ from play store. It has the new direct hotspot. The thing is, when I try to connect with another device its icon in the corner is timed out and the App on my phone says waiting.
Any suggestions?
Because your carrier won't carry non-S8 internet requests. Their connection, their rules.
aravrajak
