1. C00L FIRE's Avatar
    Yes my phone is charged and i can even check it but the phone only works when its plugged in. Otherwise every time i take the charger out, it doesn't seem to work. I tried holding the power button for over 20 seconds and each time i held it for around that time, there would be the lg logo sign that will be there for a second and then turns black screen again. I even tried taking out the battery and putting in the charger and putting in the battery and still doesn't work. If anyone can figure out this problem, that would be really helpful. I don't have a sim card and i don't plan on resetting my phone though. Thanks
    07-23-2018 03:36 AM
  2. Rukbat's Avatar
    That a sign of an almost dead battery. Have you charged it for at least 2 hours without trying to turn it on? If you have, the battery is dead and has to be replaced, but if you haven't, try that first. (Plugging in the charger when the battery is almost dead gives you enough charge for about half a second. Charging it for 5 minutes more gives you maybe a whole second. Turning it on in either case kills the battery again.)
    07-23-2018 01:22 PM
  1. Return and recent apps buttons are not working
    By ItsMeChange in forum ASUS ZenFone 4 Series
    Last Post: 07-23-2018, 08:57 PM
  2. Why is my RCA backwards
    Last Post: 07-23-2018, 01:37 PM
  3. Locked out of my buzz launcher
    Last Post: 07-23-2018, 01:35 PM
  4. How to connect car speaker to my android phone?
    By Sopno Saj in forum Ask a Question
    Last Post: 07-23-2018, 01:34 PM
  5. Replies: 1
    Last Post: 07-23-2018, 06:16 AM
