1. goodenough's Avatar
    I do not like getting interrupted by the phone.
    I am not even on vibrate. I'm on SILENT.
    All notifications are off.
    However, if there is an emergency, I want a few selected contacts
    to override the silent setting, and make the ringer sound aloud.
    Is this possible? Android 7. Moto X Pure.
    08-01-2018 10:07 PM
  2. goodenough's Avatar
    This was the missing step.
    I had to put the phone into "priority only" mode on the main pull down screen.
    https://tunecomp.net/set-up-priority...roid-7-nougat/
    08-01-2018 10:44 PM
  3. methodman89's Avatar
    You can also go to Settings, do not disturb, Allow exceptions, and narrow it down.
    08-02-2018 09:07 AM
  4. goodenough's Avatar
    Yes, but that alone is not enough.
    That is what I did but I also had to put the phone into "Priority only" mode.
    Otherwise, it would stay in "silent mode" and none of the exceptions would work
    08-02-2018 09:19 AM
  5. methodman89's Avatar
    Which Priority Mode?
    08-02-2018 09:26 AM
  6. goodenough's Avatar
    Look at the link I posted.
    You can not have it simply on "Do Not Disturb"
    otherwise, nothing will come through.
    Setting home screen dropdown MUST be selected to "Priority Only"
    Try it for yourself.
    It won't work otherwise.
    08-02-2018 11:10 AM
  1. Android software compatible with my phone
    By Jeremy Barnes2 in forum Android 7.0 Nougat
    Last Post: 08-02-2018, 05:39 PM
  2. Replies: 1
    Last Post: 08-02-2018, 12:56 PM
  3. What does the blue dot mean on the contact infor on the phone?
    Last Post: 08-02-2018, 12:54 PM
  4. i lost my contactsicon on my samsung 8 phone
    Last Post: 08-02-2018, 06:12 AM
  5. The arrow thjng is gone to download the music with
    Last Post: 08-02-2018, 06:10 AM
