1. Hepoh's Avatar
    I just got my Mate 10 pro after starting To use it i noticed the Phone feels slightly warm. Is this normal? My Last Phone Galaxy S8 also felt too warm for comfort. I can't be that unlucky? I took a screenshot, please say are these normal temp? Mate 10 Pro too warm-screenshot_20180804-151830.jpgClick image for larger version.
    08-04-2018 08:34 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. 45 C isn't THAT warm. Desktop CPUs typically run at that temp.
    Something you have to keep in mind, especially about phones is this: There is no cooling. Since phones made of metal are becoming more common, they are going to feel more warm than one made of plastic. The upside to phones being made of metal is the back becomes one big heatsink.
    As we cram more cores into SoCs, they are going to heat up. Take a look at the new MacBook Pro i9. That chip cranks out a lot of heat.
    All in all, I wouldn't worry about it too much. Modern chips will throttle themselves to protect them from overheating.
    Laura Knotek likes this.
    08-04-2018 11:21 AM
  1. [Review] Anker Power Core Lite 10,000
    By pkcable in forum Hardware Hideaway
    Last Post: 07-27-2019, 08:08 PM
  2. What happens if I return my damaged device a couple days after the 10 days?
    Last Post: 08-03-2018, 11:33 PM
  3. Replies: 1
    Last Post: 08-03-2018, 06:18 PM
  4. How do I do a simple root on a J3 Luna pro without computer?
    Last Post: 08-03-2018, 04:15 PM
  5. Galaxy Tab Pro 10.1 - System updated - Now I can only receive email - can't send.
    Last Post: 08-01-2018, 08:34 PM
