1. mdezrin's Avatar
    I've got an LG G6 and a Plantronics Explorer PLT E500 headset. I had no idea that the Plantronics would only say "incoming call". A totally useful feature - forgive my sarcasm but how does someone think that not reading your phonebook's contacts or simply announcing the number itself wasn't important. I've had older headsets that accomplished this.
    Otherwise, the headset is great - awesome battery and very good sound quality.
    So, are there any cool workarounds to override this programming faux pas by Plantronics?
    Thanks.
    08-10-2018 05:23 PM
  2. methodman89's Avatar
    The playstore has a few that will announce the caller. Use the search function for the one which suits you best.
    08-10-2018 07:10 PM
  3. DexPhones's Avatar
    Truecaller is your app i guess
    08-10-2018 09:11 PM
  4. methodman89's Avatar
    Caller Name Talker
    08-12-2018 05:13 AM
  1. Received my new OEM Battery from,)LG
    By AtTheHop in forum LG V20
    Last Post: 08-22-2018, 02:28 PM
  2. can i run adb to install custom roms etc on a pixelbook?
    Last Post: 08-11-2018, 04:16 PM
  3. Hi, I need help on decrypting my images & other files. I have SAMSUNG J2 PRIME.
    Last Post: 08-10-2018, 05:39 PM
  4. Why my battery is not charging
