1. coolblueice's Avatar
    Hello.
    Today (August 17, 2018) I just ran the Samsung Build G9350ZHU3CRG3 update to Galaxy S7 Edge.
    After the update, the Samsung on-screen English keyboard no longer has a single quote (apostrophe) as a "press and hold" over the "a" key... Now the "a" key has the same double quote over it as the "s" key (just next to it.)
    Now when I try to write can't ... it comes out as can"t. Certainly, I can tap the "!?#" key at the bottom left of the keyboard and select the 'single quote' from there... But it was so much easier when it was located over the "a" key.
    Is there some way to put it back the way it was?
    Thank you!
    08-17-2018 09:42 AM
  1. Apps moved to SD card have greyed out icons in APP DRAWER only.
    Last Post: 08-26-2018, 01:40 AM
  2. My lenovo needs an update
    By betty450 in forum Android 7.0 Nougat
    Last Post: 08-19-2018, 06:28 PM
  3. How can I see which ringtone is assigned to a user?
    Last Post: 08-17-2018, 02:42 PM
  4. What data gets erased when I remove a device from my gmail account?
    Last Post: 08-17-2018, 11:36 AM
  5. How to stop popups on lock screen
    Last Post: 08-17-2018, 09:12 AM
