1. Barryjames's Avatar
    My lg k4 phone i am trying to use the inbuilt phone number blocker when i google how to it do i follow there direction but the options are not in my phone i get a lot of tellemarket phone calls
    08-19-2018 07:49 AM
  2. Rukbat's Avatar
    1. Long-press the number in the phone log. Choose Block.
    2. Telemarketers use fake caller IDs, so the same telemarketer can call you over and over from different "numbers" while still using the same phone. (If it's your area code and an exchange close to you, you're more likely to answer.) You can't block the telemarketer, just the fake number he's using for this call. (And if it's a robocaller, they alternate numbers for each call.)
    Laura Knotek likes this.
    08-19-2018 02:59 PM
  3. Barryjames's Avatar
    If i do a long press of the number in the phone log the options i am given are copy to clip board and edit number before call
    08-20-2018 07:26 AM
  4. ManiacJoe's Avatar
    What options are available to you if you:
    tap the log entry to see the details
    then tap the 3-dot menu
    08-20-2018 08:19 PM
  1. Replies: 3
    Last Post: 08-21-2018, 09:01 PM
  2. why does my lg phone load so slowly when I restart it?
    Last Post: 08-19-2018, 04:34 PM
  3. How do I turn off speaker mode on my LG Stylo 3?
    Last Post: 08-19-2018, 04:30 PM
  4. My phone wont u no onpdate or install from gplaygoogle play
    Last Post: 08-19-2018, 07:00 AM
