Voice commands
FroggFinn
4
The "OK Google" feature has stopped working. It worked before. I have checked in the app settings; the microphone is enabled. The phone simply does nothing when I say "OK Google". This is on a Galaxy S7 Android.
Welcome to Android Central! Open your Google app, tap Menu>Settings, then under Google Assistant, tap Settings. Now tap Phone, and make sure Google Assistant is turned on, as well as Access with Voice Match. If it still doesn't work, try retraining the Voice Model.
wobblefix
