1. FroggFinn's Avatar
    Google Maps used to work perfectly. It suddenly decided to put an ad for Lyft and Uber at the bottom of the screen, where the "start" button is, so I can look up an address, but I cannot get directions. Does anyone know how I can remove the ad? The only option it gives me is to download the Lyft and Uber apps, which I really have no interest in.
    08-19-2018 03:07 PM
  2. Rukbat's Avatar
    I just now updated to the latest version, just in case - but no ads. You evidently installed something else that gave you the adds. See [Guide] Malware / Adware / Popup Removal.
    08-19-2018 03:22 PM
  3. FroggFinn's Avatar
    Thank you for the quick response. I did reboot in safe mode; the ad is still there. It appears to be from Google Play Store, and it wants me to download the apps for Uber and Lyft. I'll try reinstalling the Google Maps app. Thanks again.
    08-20-2018 09:35 AM
  4. Kodak2's Avatar
    You could try turning off notifications from Google play store.
    08-20-2018 11:43 AM
  5. FroggFinn's Avatar
    I believe that worked. Thanks, Kodak2!
    08-21-2018 09:30 AM
  1. Whatsapp cloning with Android Pie
    By Tolba59 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 03-20-2019, 01:32 AM
  2. Issues with Spotify/car controls after update?
    Last Post: 08-21-2018, 06:45 PM
  3. UrAvgConsumer just posted Real Day in Life with Note 9.
    By NIZMOZ44 in forum Samsung Galaxy Note 9
    Last Post: 08-19-2018, 02:26 PM
  4. Pdanet won't stay connected with wifi direct or USB
    By rypkr937 in forum Samsung Galaxy S7
    Last Post: 08-18-2018, 11:55 PM
