1. HighwayBob's Avatar
    I was wondering, since there is a way to "eject" an SD card is it necessary to power off the device in order to safely remove the SIM tray?
    I've always powered off, but it's a hassle sometimes and I was wondering if it's really necessary.
    08-21-2018 05:08 PM
  2. Disturbed_Angel's Avatar
    Not sure on the official/correct answer, but I hot pull them multiple times a day with zero issue. Some phones (Sony comes to mind) power down when you pull them. Now that said, with most sim trays also holding the Micro SD card, I would avoid doing so with the Micro SD card in, especially if it has activity on it. Most phones even reconnect just fine when I put the sim back in as well.
    08-21-2018 06:20 PM
  3. HighwayBob's Avatar
    Good to know. I wasn't sure if the SIMs were hot swappable. The SD cards can be "ejected" prior to physical removal so I would at least do that.
    I just needed to install a larger SD card so I ended up powering off the phone to be safe.
    08-21-2018 08:06 PM
  1. App to launch DEX?
    By txa1265 in forum Samsung Galaxy Tab S4
    Last Post: 06-20-2019, 05:32 PM
  2. Replies: 3
    Last Post: 08-23-2018, 12:19 AM
  3. How to revert changes made in Pie? Don't like some of them
    By corrinado in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 08-21-2018, 08:35 PM
  4. Replies: 0
    Last Post: 08-21-2018, 04:54 PM
  5. Can't sign even though it's in my devices
    Last Post: 08-21-2018, 04:49 PM
