1. darsh bhanushali's Avatar
    I turned the Ultra Power Saving Mode and after sending a few text messages locking and unlocking the phone it froze for a moment so I restarted the phone. Now It shows me the normal home screen and I can access my apps page but everything is turned off and I cannot turn Ultra Saving Mode off. I tried manually turning it off, restarting it, taking the battery off and putting it back on. Anyone seen this that can help me figure this out?
    P.S. I also performed the soft reset using the Volume Up/Power/Home method and when I click to clear the partition it gives me an error.
    08-24-2018 01:05 AM
  2. methodman89's Avatar
    Can you go to Settings, Battery, and choose a different setting?
    08-24-2018 06:57 AM
  1. So how many people actually got the August update?
    By strikeIII in forum Samsung Galaxy Note 9
    Last Post: 09-02-2018, 09:12 AM
  2. Replies: 2
    Last Post: 08-24-2018, 11:23 PM
  3. Why is my infinix note 4 mobile not power on and not charging
    Last Post: 08-24-2018, 06:43 AM
  4. Replies: 1
    Last Post: 08-24-2018, 06:38 AM
  5. Is this app used to hijack or hack phones
    Last Post: 08-24-2018, 01:50 AM
