So, I have the note 9 for more then a day now and I can't find a way to move my chats to the oye 9 including 2 3rd party aps i tried.
Did anyone succeed doing it? I'd love some help...
There is, officially, no process for this. The iOS version backs up to iCloud, Android can't access that and it's probably a different file format.
There may be some paid apps that can help you but these are not supported by Google, Apple or Whatsapp.
That depends on how much money you want to spend and what the chats are worth to you...You are so right. I bought 2 apps that I found can't do the job.
So you think I should keep looking or just give it up?
