1. Madz15's Avatar
    This has only happened to me since I got my S7. I'll set up Google maps and I'll lock my phone while I'm driving. After a few minutes it will say that I have lost gps signal. How do i stop it from happening?
    08-26-2018 08:04 PM
  2. Rukbat's Avatar
    When Maps is no longer the foreground app, it can lose GPS (because it stops looking), but the part that notifies you that it lost the signal isn't disabled so you get the notification. That's called an oops in programming. With an app that large, some things just don't get found before release. Email apps-help@google.com and let them know.
    08-27-2018 02:46 PM
  1. Rootless Pixel Launcher on my Essential PH-1
    By Andrew_404 in forum Essential Phone
    Last Post: 08-30-2018, 05:41 AM
  2. Want to play music via Bluetooth on my Infiniti QX50
    Last Post: 08-28-2018, 01:43 PM
  3. Dead Pixel Only Showing When Other Colours Onscreen
    Last Post: 08-28-2018, 01:39 PM
  4. Replies: 2
    Last Post: 08-27-2018, 08:17 AM
  5. When using the Android phone, the wi fi calling mode is lit up. Why is this ?
    Last Post: 08-26-2018, 07:29 PM
