1. SteveTu's Avatar
    Good afternoon all.
    I have a Samsung Galaxy J5 (SM-J530F) that I want to connect to a non-smart HDTV via HDMI. I already had an MHL 2.0 adapter handy, so I tried that but with no luck.
    Googling around, it seems that the J5 doesn't support MHL.
    I have been in touch with Samsung support and they initially told me to use screencasting/miracast until I pointed them to the original post where I'd said it was a non-smart TV (and MHL 2.0 didn't work either). So they then suggested I use an MHL cable, even though I'd told them that I'd already tried that and it didn't work.
    Finally they suggested using a usb to HDMI that supports OTG - as the phone is OTG compliant.
    I have been searching around trying to see if such a thing exists - as virtually everything that I've seen that has a micro USB and HDMI requires MHL.
    Has anyone else managed to achieve this on any OTG compliant micro usb ported phone? I now have a micro usb to usb (OTG), so all I need is either a micro-usb-to-hdmi or usb-to-hdmi OTG. Is there such a cable/adapter?
    08-31-2018 09:22 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Your best bet is probably Chromecast. If you don't have access to a wi-fi network, then try something like Microsoft's Wireless Display Adapter, which essentially adds Miracast support to your TV without requiring a wi-fi network: https://forums.androidcentral.com/e?...token=Sszuh45O
    I don't believe there's an OTG to HDMI cable that would work. For microUSB-A, I think the two standards are MHL and SlimPort.
    08-31-2018 11:45 AM
  3. SteveTu's Avatar
    Thanks for the reply- appreciated.
    Oddly, I was only in Currys yesterday evening looking at external 'smart' devices like Chromecast as they didn't have any OTG USB-to-HDMI cables/adapters in the store. I was hoping to get a cheap cable as really it was only to view photos, but it seems that a Chromecast or Miracast compatible device is the only way.
    Thanks again.
    B. Diddy likes this.
    09-01-2018 04:15 AM
  1. Replies: 1
    Last Post: 09-03-2018, 03:05 PM
  2. Android 6.0.1 can Apps be moved to an external SD Card
    By Percy Veer in forum General Help and How To
    Last Post: 09-02-2018, 12:04 PM
  3. where is space key on galaxy j3 luna pro ?
    Last Post: 08-31-2018, 11:51 AM
  4. How did my Samsung phone go back to factory reset.
    Last Post: 08-31-2018, 11:50 AM
