1. Zachzzz's Avatar
    I am using the Android Messages app on a T-Mobile Galaxy S9+ and have been unable to turn on RCS messaging. This morning I received the material design update so I checked my settings to see if I could enable Chat features (as detailed here: https://support.google.com/messages/.../7189714?hl=en) and I didn't see the options listed. I then decided to uninstall and reinstall the app. Upon reinstall I noticed that I lost the material design interface update, but when I went into the settings of the app I saw the options for Chat features. However, they were grayed out (https://imgur.com/a/RFHR1P0). I then made Android Messages my default messaging app, but then the options completely disappeared in settings (https://imgur.com/a/oTDbgvF). Have any of you experienced this issue and know the solution? Thanks.
    Edit: A restart brought back the new design but DIDN'T change the options listed.
    08-31-2018 11:57 AM
  2. B. Diddy's Avatar
    I moved this from the Android Apps forum to the General Help forum since the former is intended for developers to promote their apps.
    08-31-2018 12:57 PM
  3. Rukbat's Avatar
    Not all features of RCS are implemented yet. It's still a work in progress.
    08-31-2018 04:13 PM
  4. nucks26's Avatar
    Any idea when this will be implemented? Everyone has been frustratingly quiet about “Chat.”
    10-16-2018 06:16 PM
  5. hallux's Avatar
    Check with your carrier, and that of anyone else you communicate with. Enabling it in the apps is just one step in the process...
    10-17-2018 06:53 AM
  6. nucks26's Avatar
    I don't see the option in the app to enable it.
    10-17-2018 09:28 AM
  7. tube517's Avatar
    I use AM and it's not fully implemented yet. There's been no announcements about it recently
    I'm on the V20/Oreo/T-Mobile version and also the S8+/Oreo/T-Mobile version.
    https://twitter.com/TMobileHelp/stat...30084317265920
    10-17-2018 11:31 AM
  1. Whats the little house on my phone mean?
    Last Post: 08-31-2018, 11:31 AM
  2. How to enable call pop up notifications in emui 8.1
    Last Post: 08-31-2018, 10:49 AM
  3. An ad is coming on my home screen .
    Last Post: 08-31-2018, 10:40 AM
  4. Huawei P9 - People can only hear me very faintly on voice calls
    Last Post: 08-31-2018, 10:39 AM
