Shop Holiday deals at: Amazon | Walmart | Best Buy | Dell | Samsung
  1. outofmywhey's Avatar
    Hi guys, I have a moto g5. I noticed a new symbol on my phone. It's a stop sign with an exclamation mark inside of it in the top left corner of my phone. Can you please tell me what it means? Thanks.
    Attached Thumbnails What is this symbol on my phone?-screenshot_20180902-074425.jpg
    09-02-2018 10:52 AM
  2. Javier P's Avatar
    Welcome to the forums. Don't you get a notification related to that icon after you swipe down from the status bar?
    outofmywhey and 11B1P like this.
    09-02-2018 10:56 AM
  3. Javier P's Avatar
    If you can't see anything in there you could access the notification log and search for that record. Long press an empty spot on your screen - select 'widgets' - scroll down until you find 'settings' - tap & hold and drag it to the screen - select 'notification log'.
    outofmywhey likes this.
    09-02-2018 11:04 AM
  4. outofmywhey's Avatar
    Hi Javier, thank you so much for your help! It's a printer error GMX mail delivery notification.
    Javier P likes this.
    09-02-2018 11:15 AM
  5. Javier P's Avatar
    Glad it helped and thanks for the follow up! See you around the forums.
    09-02-2018 11:19 AM
  1. Replies: 2
    Last Post: 09-09-2018, 08:12 AM
  2. how do I get add another mailbox off my galaxy s8 phone
    Last Post: 09-02-2018, 11:28 AM
  3. Galaxy 9 fit on a Galaxy 8 exactly
    Last Post: 09-02-2018, 10:57 AM
  4. Galaxy 9 fit on a Galaxy 8 exactly
  5. Galaxy 9 fit on a Galaxy 8 exactly
    Last Post: 09-02-2018, 10:13 AM
