1. Vance728's Avatar
    I use Wi-Fi to save data but lately my phone seems slower so even though I am using Wi-Fi I turned on data also and it seems to run faster. If I am using Wi-Fi and have data turned on does my phone use data also?
    Also should I restrict background data to save battery or does restricting background data slow the phone down even if I am connected to Wi-Fi?
    And can anyone give me a crash course on how to set up my phone to make it run fast and not drain the battery?
    Thank you
    09-17-2018 10:03 AM
  2. SpookDroid's Avatar
    Depends on how the phone is set up. If it has a setting to use mobile data over WiFi when it detects connection issues, then yes. Also, unless your phone/carrier supports WiFi Calling or RCS, whenever you send/receive an MMS, mobile data will be used (and if you turn mobile data off, you won't be able to send/receive these until you turn it back on).
    Not sure what's draining your battery or slowing down the phone without taking a deeper look at your process CPU load and battery usage reports (and even seeing those it can be tricky).
    09-17-2018 11:23 AM
  1. Impressions of One Plus?
    By katmandoo122 in forum OnePlus 6 & 6T
    Last Post: 10-26-2018, 07:03 AM
  2. Replies: 6
    Last Post: 09-17-2018, 09:55 PM
  3. Replies: 1
    Last Post: 09-17-2018, 10:25 AM
  4. Speech output, want to turn off
    Last Post: 09-17-2018, 09:49 AM
  5. dual sim switch widget on Samsung
    Last Post: 09-17-2018, 09:05 AM
