1. Notabilis2019's Avatar
    Whenever Huawei Honor 6 phone is locked and picked up it randomly vibrates, how do I stop it?
    10-02-2018 02:33 PM
  2. SpookDroid's Avatar
    Do you have any notification reminder options active? Some phones have an option to do just that to let you know that pending notifications are unread, even if the screen is off.
    10-02-2018 03:25 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Also, does this happen if you turn off NFC (if the phone came with it)?
    SpookDroid likes this.
    10-02-2018 03:26 PM
  4. Notabilis2019's Avatar
    I'm not sure, how would u find this out?
    10-02-2018 06:29 PM
  5. Notabilis2019's Avatar
    No NFC on this phone.
    10-02-2018 06:29 PM
  6. B. Diddy's Avatar
    That's typically in Settings>Accessibility.
    When you say it randomly vibrates when you pick it up, does it vibrate immediately when you pick it up, or some time afterwards at random intervals?
    10-02-2018 07:44 PM
  7. Notabilis2019's Avatar
    Vibrates immediately after picking up the phone
    10-20-2018 07:19 PM
  8. B. Diddy's Avatar
    And there's no new notification icon on the lockscreen or the status bar?
    10-20-2018 07:22 PM
  1. My Note5 will not save images from online, however some it randomly saves
    Last Post: 12-17-2018, 10:24 PM
  2. Random Location Turning On...
    By AndroidFan128 in forum Ask a Question
    Last Post: 10-05-2018, 06:46 AM
  3. Vibrate after calls
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 10-02-2018, 11:39 AM
  4. Vibrate after calls
    Last Post: 10-01-2018, 12:33 PM
