1. David Barker5's Avatar
    I have the newest galaxy android s9, previously used a j7 which had the same issue, where when I use the Google search bar it takes me to a webpage that doesn't let me see or access any of my tabs unless I specifically select "open in chrome" and I would like to clarify that I HAVE fixed this before on my Galaxy J7, but it required a lot of tickering and I can not remember what the magic button was. I have uninstalled and reinstalled everything. Nothing is taking now on my Galaxy S9. I can't find any differences in the settings on the two devices so I'm at a loss what it could be.
    10-05-2018 01:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
    Open your Google app, tap Menu>Settings>Accounts & Privacy, and make sure "Open web pages in the Google App" is turned off.
    10-05-2018 02:49 AM
  3. davidtm's Avatar
    Thank you!
    B. Diddy likes this.
    10-05-2018 09:45 AM
  4. B. Diddy's Avatar
    Thank you!
    No problem. Did you also post the original question? This seems to be a different username.
    10-05-2018 02:05 PM
  5. davidtm's Avatar
    No, just saw this and related to the issue. I guess that makes me a ripple effect
    10-05-2018 02:13 PM
  6. David Barker5's Avatar
    Thank you for your help! That seems to have done it!
    10-05-2018 02:55 PM
  1. Will best buy so allow pre-orders right after the event?
    By KillerQ in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 10-09-2018, 06:26 AM
  2. Soooo.. If not Super Selfie..
    By DMP89145 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 10-05-2018, 10:28 PM
  3. Tab S2 Screen stopped working for no apparent reason
    By paulb104 in forum Samsung Galaxy Tab S2
    Last Post: 10-05-2018, 03:04 AM
  4. Why is battery draining on Note9 after update?
    Last Post: 10-05-2018, 02:56 AM
  5. Widgets on samsung s8+
    Last Post: 10-05-2018, 01:11 AM
