1. DennisOS2's Avatar
    It must exist or there wouldn't be apps to find them. Although, there are still screen savers for flat panels.
    Is there anyone out there that has had malware on their android devices? If so, was it identified and how did you take care of it? Where was it embedded?
    10-08-2018 04:30 PM
  2. Mooncatt's Avatar
    Battery/memory optimization apps work counter to how Android is designed and hurt performance, but yet they are a dime a dozen.
    It's definitely possible to have malware installed, but it's very difficult. That's why sketchy sites try to trick you into purposely installing it. Apps are unable to install themselves outside the Play store.
    Laura Knotek likes this.
    10-08-2018 06:47 PM
  3. DennisOS2's Avatar
    How is malware introduced into an Android device? Through an installed app? Code added by a remote system after clicking on a site or email link? Download an infected document?
    10-08-2018 07:36 PM
  4. Mooncatt's Avatar
    Hacked/pirated apps could have malicious code added to them. A pop-up claiming a virus was found on your phone tries scaring you into installing their fake anti-virus app, which could have malicious code. And anything else along those lines. That's why for most people it's best to leave the option to install from unknown sources turned off. It prevents those types of attacks from installing apps onto your phone.
    As far as I know, you can not get a "drive by" attack by simply going to an infected site or document. Android operates in almost a sandboxed mode, which is why Android malware typically requires the installation of an infected app.
    10-08-2018 08:35 PM
  1. Google Photos backups - Privacy and security
    By onthecouchagain in forum Android Pie
    Last Post: 11-17-2018, 06:49 PM
  2. Android auto issue buttons disappear
    By mlbyanks11 in forum Ask a Question
    Last Post: 10-09-2018, 06:31 PM
  3. Samsung Tab Active 2 scans for wi-fi every 7 seconds and stays awake.
    Last Post: 10-08-2018, 03:21 PM
  4. Best SMS between Galaxy Watch and Note 9
    Last Post: 10-08-2018, 02:52 PM
  5. Replies: 1
    Last Post: 10-08-2018, 02:20 PM
