1. Tanya Montana's Avatar
    It disables after a few minutes and switches to my data. I've tried turning my phone off and on again, switching wifi networks, but nothing has helped.
    10-08-2018 09:43 PM
  2. Scotts2019's Avatar
    Ok so my best guess would have do,ube that in your settings it is set to automatically disconnect from weak or slow Wi-Fi networks what you need to do is go into your settings (sometimes you even have to go,into advanced wifi) and turn this feature off,i hope this was to,help to you
    10-08-2018 10:51 PM
  3. B. Diddy's Avatar
    See also this thread: https://forums.androidcentral.com/as...home-wifi.html
    10-21-2018 03:00 PM
  4. B. Diddy's Avatar
    Also, if you're on Cricket, try turning off the Cricket Wi-fi Manager: https://forums.androidcentral.com/as...ml#post6334792
    10-25-2018 09:43 AM
  1. My hauwei phone has died and wont charge or turn back on any ideas?
    Last Post: 10-08-2018, 10:57 PM
  2. Why do i keep getting message pop-ups and my setting is disabled?
    Last Post: 10-08-2018, 09:40 PM
  3. Why is my batter draining so fast and not get getting charged?
    Last Post: 10-08-2018, 09:37 PM
  4. LG IMS stopped on my LG V20
    Last Post: 10-08-2018, 09:13 PM
  5. My Micro SD card is corrupted. Please help.
    Last Post: 10-08-2018, 03:31 PM
