Protect your tech:Get an Upsie warranty & save up to 70%
  1. bmaz121's Avatar
    I searched high and low for this dumb default of having the App Search search box pop up every time I clicked the Home button. It must be people like this, in order to make it default. So, to save time for you and put something out there so people can find it, here it is. First of all, I didn't know what this was called. I'll add a picture if I can.
    Fix: In settings in Nova Launcher, go to Gestures & Inputs
    Then the first entry is Home button, click on that if it says App Search or anything other than None.
    Then in the drop down list select the first entry, None
    Click the back button to return to Gestures & Inputs then click Home button to exit settings. Done. Have a great day!
    Attached Thumbnails Abdroid Home Click: App Search removal, Nova Launcher-screenshot_nova_launcher_20181009-075654.jpg
    10-09-2018 09:52 AM
  1. Data usage increased after uninsalled app
    Last Post: 10-10-2018, 02:13 PM
  2. What if i force stop mtk nlp service? How to enable it? It is not an app though..
    Last Post: 10-10-2018, 01:52 PM
  3. How do I remove an icon on my home page that is on the right corner?
    Last Post: 10-09-2018, 06:59 AM
  4. App using data after removed (data usage increased)
    Last Post: 10-09-2018, 06:46 AM
  5. How should I market my android app?
    By Prabal1 in forum General Help and How To
    Last Post: 10-09-2018, 04:53 AM
