    Hi all Thanks for clicking. I'm a heavy sleeper and am friends with an Army buddy who also has PTSD. We call each other during panic attacks and really need an app to increase my volume to max if it's on silent (Or even send some kind of alarm if the phone is off or in vibration mode?). Is there anything like that? Free would be ideal, but I'll pay if it exists. Thanks! -Spencer
    10-11-2018 12:34 AM
  2. belodion's Avatar
    Moved to General Help & How To for, hopefully, prompt attention.
    10-11-2018 05:33 AM
  3. Javier P's Avatar
    Welcome to the forums. You could set some exceptions in your Do not Disturb preferences and include your friend as a starred contact. This is what I do with my closest relatives. The right steps will depend on your phone but the process should be similar to this: go to settings - sounds - Do not Disturb preferences - Priority only allows - select these options.
    belodion likes this.
    10-12-2018 07:18 AM
  1. Why one plus 6 media starts with zero volume initially
    By Android Central Question in forum OnePlus 6 & 6T
    Last Post: 10-13-2018, 12:15 AM
  2. How do I turn down the volume on the alarm?
    Last Post: 10-10-2018, 02:16 PM
  3. Data usage increased after uninsalled app
    Last Post: 10-10-2018, 02:13 PM
  4. Why one plus 6 media starts with zero volume initially
    Last Post: 10-09-2018, 07:07 AM
  5. App using data after removed (data usage increased)
    Last Post: 10-09-2018, 06:46 AM
