1. Plkcnty863's Avatar
    When I unplug my Stylo 4 it beeps like it is charging over and over. When I plug it into the charger sometimes it says fast charging and sometimes I get a notification that says it is slow charging. It has a C style charger.
    10-11-2018 05:19 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Check to make sure the port is clear of any debris -- use a can of compressed air to blow it out. Also use a Q-tip dipped in rubbing alcohol to clean the contacts.
    Has there ever been any water exposure?
    10-11-2018 05:27 PM
  3. Plkcnty863's Avatar
    I tried the compressed air. It was a no go. As far as I know there hasn't been any water exposure.
    10-11-2018 05:31 PM
  4. B. Diddy's Avatar
    Have you tried different cables? It could be a problem with your current cable's connection. If the same thing happens with other cables, then it's probably an issue with the port itself. Is the phone still under warranty?
    10-12-2018 09:46 AM
  1. S9 Plus alarm does not work
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 10-12-2018, 04:56 AM
  2. how to stop charging mode from turning into MTP automatically?
    Last Post: 10-11-2018, 06:01 PM
  3. Google hangouts notifications not working now with Android Pie
    By Fremen1 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-11-2018, 05:58 PM
  4. lgk50 on bluetooth in my car won't show names on incoming calls
    Last Post: 10-11-2018, 05:42 PM
  5. S9 Plus alarm does not work
    Last Post: 10-11-2018, 04:46 PM
