1. reble's Avatar
    This problem is on my Metro PCS Alcatel Flerce 4 phone model 5056N. OS Android V6.0. The volume controls (Media, Alarm, Ring and notification) have changed position. The order used to be, ring on top then media, alarm and notification.
    Now media volume is on top and ring is the 3rd one down. See the screen capture picture at https://www.dropbox.com/s/axijwzfb8l8umzx/screen%20shot-sound%20controls.jpg?dl=0 The volume controls (up and down) on the side of the phone are now controlling the media volume instead of the ring volume. How do I change the order of the volume controls so that ring is back on top?
    10-13-2018 03:33 AM
  2. methodman89's Avatar
    I think you have 2 issues. The order of the volume sliders was changed in the update, and probably nothing you can do to change it without root.
    The problem of the physical up and down volume control may be related to a setting as I have attached.
    10-14-2018 10:10 AM
  1. Drop sound from my phone which drives me crazy
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 10-30-2018, 10:29 AM
  2. Camera app on Asus Zenfone Max Pro M1 is not working properly after update.
    By Android Central Question in forum ASUS ZenFone Max
    Last Post: 10-15-2018, 09:18 PM
  3. I have a email & gmail app on my phone.
    Last Post: 10-15-2018, 05:37 PM
  4. picture message problem
    By sammillerr in forum Samsung Galaxy Note 9
    Last Post: 10-13-2018, 02:39 AM
