Help: how to change Quick keys on Revolution
bluechip0309
3
As a newbie, I unintentionally moved "Lets golf 2" to the Quick Keys area of my home screen. Any ideas how to get it out of there? It is a non-deletable app but should be movable...?
Apheun
Same problem
I'm having the same issue. I went to delete an extra "music" icon from my home page and accidentally replaced my contacts quick key. Every time I try to replace it, I get stymied by the wastebasket that should have eaten the music icon...
Does anyone have any ideas?
Apheun
Figured it out!
Alright, so for anyone having this problem:
1) open your apps (via the key on your quick key bar, or however else you can get into it)
2) select the app you would like to place onto your quick key bar by holding your finger over the icon
3) continue holding the icon after the OS moves to your homepage
4) drag the icon into your quick key bar
viola.
Apparently if you are adding the app manually from the app list, the quick key bar does not turn into a waste bin and you can customize which items are on it.
Hope this helps you.
Hunter6LA
Perfect perfect perfect! THANK YOU! THANK YOU! THANK YOU!
You are my hero for today! (LG and AT&T failed...not on their sites, and not in the user manual. Boooooo!)
samyblaze
