1. What do u want's Avatar
    On the Note9 I've found that the only lockscreen shortcut app that will open right out if the lockscreen is the camera!
    The other ones only prompt the security key to be pressed in. If you have to disengage security before the app opens, then WHAT IS THE POINT OF CALLING IT A LOCKSCREEN SHORTCUT?!🤔
    Has anyone found any app besides camera that will open while the screen is locked?
    10-14-2018 11:11 AM
  2. methodman89's Avatar
    Have you cleared the cache partition and rebooted? I have no troubles using Google and Textra on the S8.
    10-14-2018 08:56 PM
  1. Home, Recent and notifications pulldown not working
    By ranibane0309 in forum Android 7.0 Nougat
    Last Post: 10-15-2018, 05:17 PM
  2. The Google pixel 3 or pixel 3xl can give us high performance with low price and is it works.?
    By Android Central Question in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 10-15-2018, 04:56 PM
  3. Why won't my keyboard work
    Last Post: 10-15-2018, 04:49 PM
  4. Replies: 0
    Last Post: 10-14-2018, 07:40 AM
  5. Picture-in-picture no longer works
    By Fret Madden in forum LG G6
    Last Post: 10-13-2018, 08:46 PM
