My phone has been laggy lately (presumably due to having low internal storage space... I will be rooting soon to help with that issue). This morning I was using my phone and it completely froze. After 20 or so minutes it was still stuck so I pulled the battery and restarted it. When it came back, it had reverted back to the stock launcher app (I use Launcher Pro). I held down the power button and did a restart at this point. When it came back, it was on Launcher Pro and all my configurations were correct.
Fast forward to now, it was being laggy and would not connect to the 3G network (I'm in Austin and I can always get 3G) so I did a restart. Started up with the stock launcher (arg!). My phone settings said that LP was configured to be the default app but it clearly wasn't starting up... I pulled the battery and put it back in, same thing... stock launcher. I removed the LP default setting hoping to be able to reset it as the default but now I can't even figure out where to go to configure LP as the default...
Any help? This is pissing me off...
Phone: HTC EVO
OS: Android 2.3 (updated on Saturday)
Phone: HTC EVO
