Hi, I had been searching for a solution but did not see any results specific to our notification reminder experience so, in case it helps anyone else, I just wanted to document that in order
to get repeating notification reminders to work
my wife and I needed to set the phone AND contacts switches to 'on' in Accessibility, notification reminders on our Galaxy S8+ and S9+ running Android 8.0
History: We just wanted notification reminders for phone calls so we turned all the switches to off and just set phone to on. We found that if we set just the phone switch on, we did not receive intermittent reminders (1 minute, 3 minutes, etc), but if we have phone and contacts turned on in notification reminders then the periodic notification reminders worked.
Would be interested if anyone else experienced this or had additional thoughts to share.
Thanks! Rick
10-21-2018 12:52 AM
