Hello,
I went for a bike ride today, with the battery about 75% full on my ~ one-year old Huawei P9 Lite running Nougat 7.0.
I had been running the Maps.me map application for about 10mns with the screen on, when the phone said it was empty and would shut down within 30 seconds.
At that point, I could no longer start it and follow the route I had planned. Thankfully, it wasn't a long ride and could get home on my own.
That issue already happened a few times while travelling, and plugging an external battery saved my bacon.
Could it be due to Maps.me crunching the CPU too much, and pulling too much power from the battery, causing its voltage to drop too much?
FWIW, here's the infos returned by the MyPhoneExplorer application while the phone is plugged into my Windows computer through USB.
https://postimg.cc/HVFNRXky
Thank you.
Edit: I couldn't find how to add a reply, so edited the original question.
ukbat >or what it's worth, the picture doesn't really tell us anything relevant to the problem (unless I missed something.
To show the voltage, in case it was relevant (isn't USB 5V?)
> I suspect, though, that you normally run the battery down until it's almost empty every time (or usually),
No I don't, but I do have the habit of plugging the phone into my computer to 1) make sure it's full when I leave and 2) to sync with Outlook through MyPhoneExplorer over USB.
From now on, I'll just make it a habit to bring an external battery + USB cable with me when I intend to follow a route, in case the phone acts up again.
Thank you.
Thank you.
Thank you.
