My tablet won't fully connect to my home wifi network.
blakehatton
3
I have a verizon ellipsis 8 running android 5.1.1 that won't connect properly to my home wifi network. My tablet says that my wifi is connected and has access, and I can browse a limited amount of websites using Chrome, but on the whole my tablet is nearly unusable.
Any application requiring internet access will not work (except youtube, weirdly). Spotify, Google Play, Gmail, you name it, it does not work. Oddly, I do get notifications for apps, but the apps themselves will not load.
I have had no issues connecting my tablet with public wifi networks, and none of my other devices have issues connecting to my home wifi. I have factory reset my tablet to no avail. The issue has persisted.
Other relevant information: The automatic time for my tablet is off by two hours. I am not sure why. It has always been this way, but has not previously impacted usability. I have in the past been able to connect my tablet to my wifi network, and it shows up in the list of devices that have connected before. However, my tablet now shows up as an "Onda Mobile V698" phone.
Where can I start looking to fix this issue?
Also, is there a more appropriate thread where I should post this question?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,601
4,741
113
Welcome to Android Central! I moved this from the Lollipop forum to the General Help forum, since it's not really a specific Lollipop issue.
See this guide: http://forums.androidcentral.com/am...roubleshooting-wi-fi-connection-problems.html. In your situation, I'd first reboot the router, which can sometimes be the simple fix (unplug its power for 30 seconds, then plug it back in). If that doesn't help, then try disabling IpV6 in the router settings.
blakehatton
3
Thanks for the move. I looked over your guide, and I'm still having no luck. My router was still set to ipv4. I tried rebooting the router like you suggested, but that didn't work either. I also checked to see if I could change the frequency band on my tablet, and that was a bust too. Is there an app I can download to manually configure that?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,601
4,741
113
You shouldn't have to change the wi-fi frequency band on the tablet -- if the network is broadcasting in 5 GHz and you connect to that network, it should connect. Or are you talking about changing the 2.4 GHz wi-fi channel on the router?
What's the brand and model of the router? Check the manufacturer's website to see if there are any firmware updates available.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Wi-Fi Analytics Tool should allow you to change channels, but I don't think that's your problem. I suspect it's a bad router. (The tablet, if it's connected to Verizon, gets its time from their towers, which shouldn't be as much as a second off (since it's GPS time, that would be a monumental failure for the entire world, including the US military) - as long as the time zone is set correctly. Or it could be a flaky Wifi transceiver in the tablet. Wi-Fi Analytics Tool will tell you if the router is flaky or not - that's he first step.
The second step is to turn off security in the router - no WEP, no WPA, set it to be open. Then you're dealing with the same thing as a public network. If it still doesn't work, it's still probably the router. If it does, pick a security (SPA2 Personal with AES encryption is just about universal, and more secure than TKIP) and see if that fixes it.
blakehatton
3
Apologies for bumping a month-old thread. School and work have a tendency to conspire against my available time. Rukbat, I borrowed a sim card from a family member's tablet and that cleared the time issue up. I also disabled all security on my wifi network and made it open. My tablet was able to connect to the wifi with no issues and was able to stay connected for about 10 minutes after I turned the security back on. However, the issue reared its head again. My wifi is through xfinity. I looked at my account online and was not able to find where to edit the security options beyond "WPA2" or "Open". I know this is probably not your field of expertise, but do you know where I would find that?
lindagibney
