    I'm new to Android TV - just purchased two Sony Bravia TVs with built-in Android TV. Can I clear unwanted icons (apps, recommendations, etc) from the screen? The Home screen is too cluttered with stuff I don't want to see every time I turn on the Sony TV. I've tried uninstalling apps and other Home Screen settings but no luck. I want to customize my home screen to simplify it but it appears Android TV has programmed several fixed images or icons that can't be removed
    11-12-2018 11:41 PM
  2. Rukbat's Avatar
    Have you tried long-pressing an icon you want to get rid of? There should be a menu when you do that, with a Delete choice.
    Or just drag one unwanted app to another, and they should form a folder. Keep dragging unwanted apps to that folder. You'll still have one folder, but just one, not many.
    [Second post added to original thread to avoid duplicate answers.]
    11-12-2018 11:54 PM
  3. Bruce23g's Avatar
    I'm new to Android TV - just purchased two Sony Bravia TVs with built-in Android TV. Can I clear unwanted icons (apps, recommendations, etc) from the screen? Its too cluttered with stuff I don't want to see every time I turn it on. I've tried uninstalling apps and other Home Screen settings changes but no luck. I want to customize my home screen but it appears Android TV is programmed several fixed images or icons that can't be removed?
    11-13-2018 01:54 PM
  4. Bruce23g's Avatar
    My devices are not portable (smart phones or tablets) - they are a 65" TV and 42" TV with Android TV control built in. I'll experiment with them, but I don't think the cons are accessible by touch or drag (I can only select the icons with TV remotes).
    11-16-2018 06:42 AM
  1. Power button - how do i stop screen from immediately locking when pressed?
    Last Post: 11-17-2018, 02:08 AM
  2. why my galaxy s8 screen is malfunctioning?
    Last Post: 11-13-2018, 12:02 AM
  3. Full screen reminder in YouTube
    By sr2382 in forum Samsung Galaxy Note 8
    Last Post: 11-12-2018, 07:28 PM
  4. Phone keeps flashing white on the bottom left corner of the screen
    Last Post: 11-12-2018, 07:27 PM
  5. Notifications customization
    By toodloo in forum Samsung Galaxy S7
    Last Post: 11-12-2018, 04:41 PM
