1. 7875504044's Avatar
    Hello friends,
    I successfully installed Lineage 8.1 (along with gapps) on my Redmi Note 4 and is working perfectly fine (without any crashes/hangs for last couple of days. But there're some issues like
    1) I tried to install TWRP multiple ways but it doesn't enter TWRP recovery mode on its own (when I press volume down+power) but instead it always stuck up at "Fastboot". So I use laptop to do that job every time I want to go TWRP recovery mode, by running 2 command at "cmd prompt" from laptop (this method works fine) =
    fastboot flash recovery recovery.img
    fastboot boot recovery.img
    IF I try to install TWRP using xiomitool it throws "Error 1006: The device is offline or unauthorized" but from cmd prompt I see device list with "adb command" without any issue.
    How can I solve this issue to make my phone to TWRP (without using laptop) when I press "vol-down + power"?
    2) Now that I'm running custom ROM 8.1 on my redmi note 4, how to update it regularly, Does it get updates on its own OR should I manually download Lineage 8.1 updates/apply them?
    3) I did NOT root my device and am not interested to do that unless its of great advantage. Please advise if I should do that. If yes, which method is the best one (Magiks/Supersu etc.)
    Thanks!
    11-14-2018 09:32 AM
  2. 7875504044's Avatar
    for point 1# I got solution that I need to press vol-UP + power (not vol-down button) silly me!
    but I need someone'e kind solution on point#2 & #3
    Thanks!
    11-14-2018 03:02 PM
  1. Why can't I repost a story to my own story [Instagram]
    Last Post: 03-11-2019, 06:16 AM
  2. Replies: 6
    Last Post: 11-19-2018, 12:46 PM
  3. Replies: 1
    Last Post: 11-14-2018, 12:53 PM
  4. Replies: 1
    Last Post: 11-14-2018, 11:59 AM
  5. Ads pop up on my homescreen (Samsung galaxy a6 2018)
    Last Post: 11-14-2018, 08:49 AM
