1. glittern1nja's Avatar
    Hi all. I desperately need a way to change my notification icon for texts to something that is not white. Obviously, white icons cannot be seen on a white background, and nearly every app I use turns the notification bar at the top of the screen white.
    I used Textra for quite some time, but they now say that Google won't let them have any color but white for the notification icon. I absolutely need one that isn't white -- can anyone please help?
    11-15-2018 11:22 PM
  2. hallux's Avatar
    If Google won't let them use anything but white, then NOBODY can use anything but white. You won't find one in that case.
    In the cases where the notification bar is turned white, the icons should invert to black - this is how my Pixel 2 XL works...
    11-16-2018 04:56 AM
  3. chanchan05's Avatar
    Apps that turn the notification shade white also turn the icons black automatically. That's been normal Android operation for several years. You don't need to worry about notification icons.
    11-16-2018 05:02 AM
  1. “Hey google!”, lock screen issues and notifications
    By Arsenio Martins in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 11-20-2018, 05:46 AM
  2. Replies: 1
    Last Post: 11-16-2018, 06:41 AM
  3. Replies: 2
    Last Post: 11-16-2018, 05:11 AM
  4. Replies: 1
    Last Post: 11-16-2018, 02:36 AM
  5. How do I get rid of text to speech
    Last Post: 11-16-2018, 02:30 AM
