1. Buddhadelight's Avatar
    I have activated it and now cannot be removed. No access to removed fron screen. Any help please?
    11-16-2018 08:41 AM
  2. Javier P's Avatar
    Welcome to the forums. Which dictionary app? Is this an app that you downloaded or did it come preinstalled? If you downloaded it go to the security settings and make sure it is disabled as device administrator.
    11-16-2018 09:04 AM
  1. How to restart my phone without the power button?
    Last Post: 11-16-2018, 05:04 PM
  2. How to move memos from s5 and s6 edge plus to s9
    Last Post: 11-16-2018, 12:31 PM
  3. Voice mail is corrupt, how to reset it or reinstall it
    Last Post: 11-16-2018, 11:54 AM
  4. Auto drive msg on when should be off
    Last Post: 11-16-2018, 09:55 AM
